U1131 code, causes and fixes
1 reading
4.9K views 7 replies 4 participants last post by  Ryanjacob
Hey everyone, I’m not a Lamborghini owner, yet, but I’m a technician that works at a shop that works on these cars. In the shop we have a 2012 Aventador that’s showing multiple codes and not starting, the starter kicks on and the fuel primes but there’s no start. It’s showing 2 U codes and 1 P code. The main one being the camshaft timing code U1131. What are possible causes of this code and causing it to not start? I just began working at this shop and am still learning the complexity of these vehicles and online searches don’t help because it’s not a common car to work on. And this car has been being diagnosed since before I started. Any help or guidance would be greatly appreciated.
PS: the other 2 codes are P139E (O2 sensor) and U1130 (air leak at/near #1 O2 sensor).
Thank you for the help in advance
#7 ·
Hi, could you please give us an update on what was the exact issue. My friend has an Aventador with exact problem and fault codes. Initially I was thinking the tracker disabled the ignition but after disabling it problem still persist. Managed to start the car few times but engine stops while idling, keeps running if under load even at slightly over 1000rev. Also strong smell of petrol when running, and had few times missfire earlier at idle seen rev counter oscillating. Any info would be appreciated. Thanks
