I have been intending on starting this thread for a little over a year now when I first started the project but am just now finding the time to do so. I was finally able to purchase my all time dream car in July of 2015. It came out of Oklahoma with 55,000 miles on it. It had a broken rear axle so it couldn’t be driven. Unique upgrades were a big brake kit, Hercules Muci wheels, Carbon Kevlar Spec clutch, and an MSD ignition. Despite many negative posts about the car on forums I bought it without seeing it myself but did have it inspected. For the price I paid I expected to have to go through the entire car but it was quite a gamble! Below are some pictures of it when I first got it.
I bought the car with a broken rear axle so needless to say, that was first on my to do list! I looked into having one made at a local machine shop that specializes in axles but went with the factory one instead. Custom would have been about $500 vs. $2,500 for factory. Still trying to figure out how you break an axle on a Diablo, not only once but twice!
Once I was able to drive it I came to the realization that it overheated after driving for about 20 min. It was quite a journey figuring out what the actual issue was and once I discovered what the issue was I felt like such an idiot for not figuring this out right away.
Tip, if you don’t have heat, and your car overheats, it’s probably your heating system not your cooling system! In Southern California we don’t really need heat but I should have check that first.
In my hunt to find the issue I replaced, radiator cap, temp sensors, rebuilt water pump, replaced and tested thermostats, flow tested radiators, and lots and lots of bleeding. I even took it to my local independent shop and they diagnosed it as bad temp sensors and air in the system. I finally decided that it must be a bad head gasket leaking air from the cylinders into the coolant. Since I was planning on pulling the motor and doing all of the gaskets anyway I figured I would go ahead and do the head gasket and hope that was it. I had also done a leak down test and found that the valves were far out of adjustment.
