In the middle of the drive the car had loss power and misfiring. Took it home and ran a code check of P1426, P0157, p0227 with bank 1-10 blinking. After much research it sounded like a fuel pump issue. Bought a used working one, replaced and installed on bank 6-10 LHD and reset codes. Turned on ignition, and the Gallardo was very weak but it did turn on. The misfiring is gone but there is still significant loss of power. Let it idle and check engine light eventually came on, this time code P0157, and P0151 bank 6-10. Checked fuses for fuel pump 1-10 and all are fine. Swapped them around and no difference. I’m not sure what else to look for. I did smell gas while idling. I searched on here and can’t seem to get a clear answer. Do I need to replace the other fuel pump? Is it oxygen sensors? Any help would be appreciate, thanks!
