Does anyone have interconnect schematics, specifically for the CAN wiring and E-gear ECU? OBD reads "no link" and even TEXA can't direct to the problem due to CAN not giving feedback to ECU status. Thanks
Start on page 1096 wiring diagram. Looks like 3 wires to ecus from can connector. #1 pin on can connector is probably a ground. Pages following 1096 show where the wires connect. Not your normal flow diagram. I am not an expert.
Is this the page? What is connector 409 connected to? 29R?, 29L? 279? EL0201? Where is the index descriptions for what these numbers represent? If I had that info I could easily troubleshoot.
I will look into that when I have more time and see if I can connect those dots. The 409 should be labelled GFA if that is what it is connected to, I'm pretty disgusted that they did not do that labelling! Lamborghini has the index but will not give it out... they want your $$$$$..
I suspect the GFA first and then the E-gear ECU which has power direct from the battery to charge the pump and make sure it is in neutral before powering the engine ECU's for start up. I get E-gear alarm on the dash when cranking the engine. Thanks much for the help!
I believe the bullstuff CD is the same manual we are looking at and wants $250 to ship it. Not happening.
I think the TEXA will work fine except for the issue I have. It displays all the data like clutch wear ect but the E-gear test will not function. It also connected to the OBD where my handheld only displayed "no link". I can tell more after I figure out the break in the CAN communications so I can run the various tests.Agreed, but this what is available for free. What is your opinion of the Texa diagnostic tool? I'm considering a purchase.
