Car Spare Keys
4 reading
2.8K views 11 replies 6 participants last post by  Ozzir
Gentlemen,
i lost a box with spare keys for my Gallardo and Murcielago LP640. I hope they can be found as soon as possible, however i consider to buy additional FOB keys to make sure that cars are under control.
What would you recommend me? Where can i buy them? How should i re-key them and reprogram an immobilizer?
It is a real pain for me.
Any opinions would be appreciated.
#6 ·
I have got messages from Lambostuff and Ricambi, in which they described what the replacement of keys means. Anyway i should discuss it with a dealer deliberately.
Of course it is reasonable to send another message to Glen.
Thanks, gentlemen.
I will keep you in the touch.
#7 ·
The key is cut by the factory specifically for your car according to the records they keep on file. I found that Glen offered the lowest price. From the time I ordered the key, it took about two months until it arrived. This is due to the time the factory needs to get the job done (I guess they're not in a hurry) plus shipping time.
Once you receive the physical key, you must take it to a Lamborghini dealer to have it paired with your car using the LaRa software. Getting a spare key is expensive and time consuming, but if you have only one key and you lose it, you've got a big problem, especially if the car is locked and in a remote location.
#8 ·
What an amazing response! Thank you so much. I have to admit that this issue should be resolved carefully. Frame time is not a big deal for me because i focus on the security and quality.
I appreciate it and love this forum!
#9 · (Edited)
Couple of other thoughts. If you loose your only key, and the car is locked, you've got a big problem. I took my key to a local locksmith who had the same key blank that Lambo uses (it's used on a number of other cars as well) in stock and was able to duplicate my key for about twenty bucks. The key won't start the car without a properly programmed fob, but it will open the door and turn the car on. You may find a good hiding place for it under the car.
If you can't unlock the car using the buttons on the fob because of a dead battery in the fob or in the car, you can open the door with the real key or the key blank if you have one made. Problem is, when you try to slide the tab down that covers the door lock, you've got about a 90% chance of breaking it. You can't just buy the tab separately, but will need to buy the entire handle assembly which will then need to be painted and installed from inside the door. The other option is to glue the tab back into place or use velcro or something on it. Best advice - Avoid getting in to a situation where using the door lock is the only option by changing the fob battery every year and not forgetting to turn of the lights when you park the car. If you've got a weak battery and will be leaving the car, consider keeping the drivers window down.
The dead car battery issue is a concern. Most folks have a trickle charger they connect to the battery, but the connection cable and charger are usually kept in the trunk. If the battery dies and the car is locked, the've gotten to get the trunk open to begin charging the battery.
I took a different approach. Since you can buy a battery tender at any auto parts store, and since they all use the same type plug to connect to the cable and fuse that is attached to the battery, I just got a longer cable, attached it to the battery and ran it up behind the drivers windshield wiper arm where it is hidden from view, but easily accessible from the exterior of the car.
If I have a dead battery and a locked car, I may be able to get to an auto parts store, buy a new tender and charge the battery. If so I'm back in business. Without this setup, I'd have no way of accessing the battery without opening the door with the mechanical key and likely breaking off the tab while trying to remove it.
#10 ·
Hi KeithM:wave:
excellent advice all round.:tup:
I will try the remote battery tender extension connection as have had drivers door handle key cover tab broken off already:(
I might try alternative site on my LP in the central front bumper vent.
When parked in my garage, I always keep car unlocked, so can pop the hood, in case have to change out battery or do a jump start.
cheers,
john
#12 ·
Yep me too. Car is left unlocked in the garage at all times. Just in case. You never know when something will happen and it would be a pain in the ass if the battery dies and the car is locked. Window down is a good idea too if you arent worried about any dust getting in the car.
