Thank youI’m pretty sure it goes to the coolant outlet collector. With the manifold in place it will require luck, patience and a lot of swearing. With the manifold away it’s an easy job. The red arrow shows where it used to sit 😊
Looks like that’s for the other line?I’m pretty sure it goes to the coolant outlet collector. With the manifold in place it will require luck, patience and a lot of swearing. With the manifold away it’s an easy job. The red arrow shows where it used to sit 😊
Sorry then I was wrong. Then the first one you asked about goes to the front bleed line in the propeller shaft tunnel. It’s close to where the two fuel tanks are connected.Looks like that’s for the other line? View attachment 298249
