1 - 20 of 34 Posts
To make the stock 20" Huracan wheels flush what is the recommended spacer 11mm or 15mm? I see both are being used.
Thank you
17' SV Roadster, Performante Spyder X2, STO (inbound), Ferrari 458 Spyder,
Agreed the 15mm are the perfect distance. Not too big not too small. RoadRonin, your setup looks fantastic.
I have 15mm in stock. All excess material has been machined off so they are superlite.
Some pics of my car
I have your kit and it is quite nice. Out of curiosity what is the weight of all 4 spacers?
Discussion Starter · #11 ·
Some pics of my car
Are you running the 15mm in these pics?
Anyone have pics from a angle showing how flush the wheels are with spacers?
Any issues with the 15mm spacers causing tire rub?
Depends on how low you go. I will admit to having an occasional rub at max compression. I may switch to 11mm for the front to see how that goes. I like the way my car sits now so I'd rather not raise it.
I may take a photo later today to try and capture an angle that shows how flush the wheels are.
Hopefully, these give you some idea ...
295185
295186
295187
The following is the stock ride height (and no spacers)
295188
295189
Discussion Starter · #17 · (Edited)
Here is my 610-4 with Mimas and10mm spacers off my audi just for a trial. The rear is perfect with the 10mm however the front could use 13mm or 15mm and be flush. I don't dare go with the 15mm. With the 305 wide tire mine is already sticking out past the fender on the rear. Different stock wheels must have different offsets.
295224
295225
Discussion Starter · #18 · (Edited)
Does anyone know the actual offsets of the stock 20" Mimas?
I read 42mm front and rear although I've also seen some other specs. I took my wheels off and the specs are not on the wheel barrel as some other wheels are.
Here is my 610-4 with Mimas and10mm spacers off my audi just for a trial. The rear is perfect with the 10mm however the front could use 13mm or 15mm and be flush. I don't dare go with the 15mm. With the 305 wide tire mine is already sticking out past the fender on the rear. Different stock wheels must have different offsets. View attachment 295224 View attachment 295225
The reason your wheels stick out a bit is because your car sits higher than mine. As you lower a car the wheels begin to tuck in. I didn’t feel that I really needed spacers until I lowered the car.
1 - 20 of 34 Posts
