1 - 7 of 7 Posts
Does anyone know if engine oil can be added via the dip stick channel rather than vis the engine compartment with a screw cap marked "oil"?
The reason I am asking this is that I cannot get to the screw cap as it is blocked by some wires and I cannot unscrew the cap.
I see no problem with using a funnel at the dipstick. I would imagine that you'll have to pour it in very slowly. The oil may back up in the tube a spill all over the engine. So pour slowly. :)
Thanks for your advise.
Will try it tonight.
After having tried to unscrew the oil filler cap its given me a bloody finger and a blister to go.
So I am not going to try again that way.
I only need to add a small amount of oil anyway so it should be fine going down the dip-stick tube.
Eric, I have a tractor that fills through the dipstick hole - so there's no problem.
This might sound silly - but if you warm the oil first it will make it thinner and easier to pour, so it won't back up and overspill.
Agree with David it will not do any harm. But like he says, add very slowly to avoid spilling.
For the future, get a medium sized pair of Channel Lock Pliers and open the jaws to fit the cap and unscrew it intially with the pliers using a rag to prevent scratching. Then replace by hand, so it's not so tight next time.
Regards, JRV
1 - 7 of 7 Posts
