Great info. Thank you! That probably explains why my old impeller had a crack on the side of one of the two holes. They probably tried turning it clockwise.The impeller is screwd on CCW. Use the 2 60mm spaced 6mm holes in both impeller and pully to undo. Use a specific tool, or be creative. Remember CCW threads.
The pulley is pressed on to the shaft. Its pressed so shaft pulley surface is flush.
An allen set screw is holding the shaft/bearing assembly. You only get to it with the pulley removed.
The mechanical seal is pressed into the housing ø40mm and the rotating ceramic part is ø35 on the impeller side.
Impeller is torqued to 30nm.
ANY leads on a replacment seal, lambo part is marked up x20, literally. ???
I had second look; no, seals do not read anything on them. I suspect they are found from more common source, since seal got so many parts in them.@mikael82 please take a picture of the spare seal you have, any generic numbers on it?
who did your rebuild? My bearing is also bad, so need it completely rebuildI previously sent mine out to be rebuilt so I can't say for sure but mine is out and looked at it recently and thought it looked like it was pressed. I would like to know for sure if this is correct.
Sorry, I don't recall the name of the place and can't seem to find it. I believe it was in the northwestern US. I will look through receipts to see if I have it.who did your rebuild? My bearing is also bad, so need it completely rebuild
That's must be what the one was that I bought years ago to scavenge parts off of. I bought it for $150 and used the pulley and impeller (since mine was damaged) off of it to rebuild mine. The place that did my rebuild bought the housing back from me for like $75.I was in luck; there is waterpump for VT -cars that does not have powersteering and many people have bought wrong one; got it cheap.
Mine is totally new, with pulley and everything.That's must be what the one was that I bought years ago to scavenge parts off of. I bought it for $150 and used the pulley and impeller (since mine was damaged) off of it to rebuild mine. The place that did my rebuild bought the housing back from me for like $75.
