My car does not have these lights and according to the wiring diagram there is no such light in these gauges in an Urraco. But in general lights going on on strange moments happen when there is a bad mass connection.Problem: the red warning light inside the Ampmeter and the coolant temperature gauge is turning on when I switch the light on. When I switch the light off they disappear.
any ideas are welcome View attachment 290228
well since you have the same car you should have the same gauges with the same warning lights inside. But the mass connection is a good hint. how can I check??My car does not have these lights and according to the wiring diagram there is no such light in these gauges in an Urraco. But in general lights going on on strange moments happen when there is a bad mass connection.
GRS Paul.
Samba lee, although many gauges are equipped with a red warning light this red light is only used in the fuel level gauge and the oil pressure gauge. The diagram, at least for my car, is 100% correct.But unfortunatly that diagram doesn't show the warning lights you can see![]()
Yes I understand. I guess some cars had the warning lights wires on those other guages. I think mine is like yours also.Samba lee, although many gauges are equipped with a red warning light this red light is only used in the fuel level gauge and the oil pressure gauge. The diagram, at least for my car, is 100% correct.
GRS Paul
