Did you just get the car, or did you put in the bulk of the 1,300mi?
If the former, I'd say to just check the oil level if possible. I'm not familiar with Audi's 4L V8 (Urus uses a modified version), but hopefully it'd be possible to drain the oil a bit in this case -- too much oil is almost as bad as too little.
If the latter, I'd have a tech check it out since oil doesn't magically dive into your engine.
