1 - 7 of 7 Posts
Hey guys, was hoping I may be able to get some help here.
I have a 2010 LP 560 and the front tire pressure sensors started to go in/out due to low battery. I had the front ones replaced at discount (from what other guys said worked for them here) and now I have a TPMS light that won't go away.
When I turn on the car it will blink for a bit then stay lit. The dash shows the front left/right sensors are Red and the rear two are green.
When I check the tire pressures on the dash (via the stalk/menu controls) I am showing pressure on all wheels.
The discount shrugged their shoulders and said they don't know what to do.
any ideas?
Thanks!
The rear ones need replaced as well. Strange they only told you to do the front. This is normal as you have a 2010 and you always want to replace all 4 front/rear together. It's battery issue and you said you only did the front ones.
I second that. You need to replace all four. They can often still transmit pressure information with a low battery, but will be signalling that they have a low battery which causes the error.
Discussion Starter #4
I am starting to think Discount installed the wrong ones in the front. I went to the store that installed them to have them do the rears, and they were not really sure which ones the car needed, and it was a couple months ago so they were very unaccommodating. I decided to not have them do anything else to the car and cut losses
I ordered the correct 4 sensors and will install them/balance the wheels at a friends place that has the tire equipment.
Cool. Where are you located?
Cool,. Colder temps make that go bad faster...
1 - 7 of 7 Posts
