Tire size help..
1492 Views 3 Replies 3 Participants Last post by  JW1
What is the widest size tire, you can fit on the rear of Huracan Evo RWD..
19" and 20" spec?
Any help would be appreciated...
Thanks
1 - 4 of 4 Posts
Well mine has 20" so that is a certainty not sure if it will accommodate a larger wheel (21") but the forum experts will educate us no doubt.
I want to know what the widest width tire I can fit on a 19" or 20" wheel.
Example 325x30x19 I know that should fit on rear.
But can I fit a 335x30x20 on the rear? Without modification.
You probably have to go to 335x25/20 to keep the diameter within 3%. Also, with the correct offset, I bet you can do 335 no problem.
Reactions: 1
1 - 4 of 4 Posts
