Tillett Bucket Seats in Aventador SVJ (US)
314 views 4 replies 2 participants last post by  Uberhorst
tldr: This thread describes how to install Tillett bucket seats in the US spec Aventador w/o getting any airbag warnings.
I've scoured the internet for Aventador seat mods before I took on this project. The car is exclusively for show and shine, not driven on the road and so I wanted to get a seat that matches the interior looks of the SVJ w/o the requirement of being comfortable. My choice fell on the Tillett B7 for several reasons:
  • Carbon fiber looks
  • Lightweight
  • Narrow enough to fit
  • Extremely low seating position
Removing the old seats
Removing the factory seats is a relatively simple task. The 4 bolts are easily accessible, the seats are not that heavy.
Mounting brackets
The factory mounting points are in a single plane. Even better: Tillett's sliding rails can directly be fastened to those points. The tricky part is that the factory seat is not centered around the mounting points. I ended up using a combination of inside and outside mounted rails/brackets.
With this combination the brackets cannot be moved close enough to each other to directly mount the seat in between, so a spacer is needed. I made one out of Aluminum on my lathe.
Seat belt
The factory buckle is too long and does not line up with the opening in the seat, so a shorter one is needed. I ended up using the buckles from a 2014 Mercedes ML. An adapter is needed to allow mounting the buckle to the rail brackets. I built it out of mild steel and powder coated it in black. A welded nut allows for easy installation of the bucket and an adapter allows the use of a “reasonable” bolt size.
Electronics
This is arguably the hardest part and one that many people shy away from. The way I approached it is to first build a wiring harness that plugs into the factory seat harness and that is long enough to plug it into the factory seat outside of the car. Together with a wiring diagram this allowed me to measure certain voltages/resistances. I then used an OBD tool to check the interpreted signals on the vehicle side. For the US spec passenger seat, we need the following:
  • Seat occupancy mat: This uses a 0-5V pressure sensor. Different thresholds are used to indicate child seat vs passenger. I used a potentiometer to emulate this.
  • Seat buckle strain gauge: This is another signal that’s used for the child seat – I think it is not used as a control input during airbag deployment. The output is another 0-5V signal.
  • Seat belt buckle switch: Two resistors used to identify open circuit + whether the seat belt is buckled. A resistor does the job.
  • Seat position sensor: On/off switch that indicates the seat position. This is the one I was most surprised about. It really only triggers when the seat is all the way to the front. Moving it ⅛” deactivates it. Not sure why they did it that way. The easiest way to mimic the sensor is to use the original one and bring it close to a piece of steel. The sensor will pick that up and tell the ECU that the seat is not all the way towards the front.
  • Seat airbag: That’s the easiest one. A fuse and a resistor will do the job
If you have any specific questions I’m happy to answer them. This was the first mod that I did to the car and I'm planning to share the others as well.
#2 ·
Welcome to the forum, interesting mod you are doing to the SVJ, I have seats in my aventador S that have been changed not by myself (original aventador S seats are not very comfortable) but by a previous owner and have been living with the dreaded air bag light because of this. Diagnosis has something to do with the passenger seat module which no one has been able to get resolved. Sounds like you have a good background in electronics to troubleshoot and diagnose.
