1 - 1 of 1 Posts
2017 Superlite SLC Race Tail
This SLC was professionally built by Allen Uziak and was delivered in June of 2018. It is powered by the Corvette LT4 engine with a 15% overdrive kit and balancer giving it around 740hp at the crank. The color is a GMC color called Stone Blue Metallic complemented by CF5 satin black rims. This SLC was built with all the new upgrades and options, and was made to be a show stopper. You are a Rock-star when driving this car. I have gone on several 400+ mile road trips, as well as Houston to Dallas several times. This SLC is very reliable… It is kept in a climate-controlled garage. Have over 175K in build and can provide build list and prices. I have had the car for two great years but am looking in get into something different. Below is the build list showing all options.
PRICE - 150,000.00
Make: RCR
Model: Superlite Race Tail
Mileage: 5,200
Asking Price: 150K
Superlite Base Kit
Carbon Fiber Tube Assy.
CF5 Wheels Satin Black – 18” front / 19” back
Fiberglass Fender Vents – integrated into body and painted
Fiberglass Aspire Rear Window with vents -intergraded into the body and painted
LTS Engine mounts
Flywheel
LT4 Engine with dry sump system and 15% overdrive pulley and balancer.
Dry Sump Oil System – lines, oil tank with overfill tank.
Engine Controller
GM accessory drive
Graziano 8 Transmission – with bearing and 1.04 drop gears
Tires – Michelin Pilot Pro and Pilot Sport.
Emergency Brake – electric and hidden under dash
Seat Belts – Sparco 4-point harness
Exhaust – custom pipes with 4” magnaflow mufflers.
Sound deadening and Heat Shield – throughout the entire cabin.
Air Conditioning – Blows Cold.
Heater Bypass
Intake Tube – Polished with air filter
ISIS Electrical System.
Door Actuators – open with key fob, no door handles.
APR CF Mirrors – adjustable
Ceramic Coated Exhaust
Tillett CF Seats – One piece with pads and brackets
Battery isolator and master power shutoff
Raptor Pro steering wheel with buttons
A Pillar covers – sprayed in alsa’s soft feel paint
Dash Board – sprayed in alsa’s soft feel paint
Rear lights – Lotus
MOMO steering wheel and quick release hub
Aim Instrument System.
Front Lift System – button hidden under dash
Back up camera
Audi R8 Gates Shifter – custom center console with Alsa’s Soft Feel paint
Painted Brake Calipers – Lime Green.
Stereo - Rockford Phosgate w/ Bluetooth, Alpine amplifier, Focal K2 Speakers, tweeters, door speakers with custom center box.
Spal Fans
Nose / Lower vent modification
LMR engine management
Corner Balancing and alignment
HalGuard Fire Extinguisher
Carbon fiber stereo console
Carbon fiber door inserts
Carbon fiber front splitter
Carbon fiber side skirts
Carbon fiber rear wing (lowered)
Contact me for more Dropbox pictures and build sheet.
1 - 1 of 1 Posts
