I am sure Dallas performance could build a supercharger system. It is not rocket science. I fabricate all my own stuff and their skills are way beyond mine. You just need a centrifugal blower with the right AR and size for what you are looking for. Upsize the injectors and pump. Add an intercooler . Tune the whole thing and Shazam. There are tons of aftermarket components you can adapt.(Elbows, hoses, etc) The pulleys might be the only tricky part. I have a lathe so make my own adaptors. If you go with a lot of boost , you will need wider pulleys. They will have to be fabbed. You can probably run 5 to 7 lbs with stock pulleys and serpentine belts. Should not be too expensive.
