Haha I love the downshift and that sound ❤ but I somewhat enjoy going straight to N sometimes, I just don’t want to cause any damage if that makes sense lol.Never! You’ll miss all those glorious downshifts.
Thank you for the reply! Im coming from a 911 4s so the move up has me a little cautious on how to drive It. Its so fun to drive, I know the eager has a bad rep but its so fun to drive!Like Murciful said, you'll miss those downshifts but it wont hurt the car at all. In fact, it'll save some wear on the clutch since you'll skip all the downshifting
Thank you for confirming.No problem at all. You are fine to go from whatever gear to N
SameI always shift to N and roll to the lights- was told it saves the clutch.
Awesome, maybe I'm being over picky but its my first exotic and I'm scared.No problem at all. You are fine to go from whatever gear to N
If you want the clutch, transmission, diff gears, u-joints etc. to last a long time let it coast using the brakes. The downshifts while slowing down gently/coasting sound cool but you are putting all that extra wear. Downshifting to slow down a car is not recommended it wears out tremendously.
Brake pads may cost a few hundreds but a clutch several thousands.
[/QUOTE
Amen, I agree![]()
Nice car!With my Murcielago I go into neutral as much as I can, especially going down hills. I also always have it in sport mode. For me it’s all about saving the clutch.
Thank you, if it’s a steep downhill grade and the car is really accelerating I will put it in gear to slow it down a little then go back to neutral, so I don’t really use the brakes much going down hill. But the steep downhill grades and the high temperature issues are not really an issue where I live. My understanding of the clutch mechanism is the wear mostly comes into play as the clutch is engaging thus the wear on the clutch surface. Things such as not using sport mode for example. If not using sport mode, the clutch will slowly and smoothly engage but is causing wear as it slowly engages. Whereas sport mode will slam it which reduces wear on engagement because it is more of an instant engagement than slowly engaging, and makes for a much less smooth engagement that you can feel. Another thing you want to avoid with e-gear is reversing and even more important is never ever if you can help it reversing up a hill. Your other point, my understanding is yes if it is fully engaged it won’t be causing wear. I could be wrong but if the car is in neutral, there is no pressure or engagement of the clutch.Nice car!
Correct me if I’m wrong, but the clutch mainly wears when it’s not fully engaged and the rotating speed between Drive shaft and gearbox is different. Once fully engaged, there’s no wear. So going downhill with an engaged clutch should be no issue. The blipping when downshifting is partly to help reduce wear when the clutch is engaging the new lower gear, though admittedly it doesn’t prevent wear.
my worry when coasting downhill in N, assuming big descents, would be to cook the brake fluid and loose all braking capacity. Of course subject to a little humidity in the fluid. In our Malaysia climate that’s a potential issue.
in all case..happy driving!
