Just make sure to install the passive inline crossover for the tweeter that comes with it….as the factory one also has one on the speaker itself. Otherwise those lil tweeter will turn to fairy dust. Lol I learned the hard way, lololMight need to try this out. Thanks.
Help me out, passive inline crossover?Just make sure to install the passive inline crossover for the tweeter that comes with it….as the factory one also has one on the speaker itself. Otherwise those lil tweeter will turn to fairy dust. Lol I learned the hard way, lolol
There is a factory amp with one huge signal (essentially one plug), and we use the passive crossover to split the huge signal into two or more signals to go into the tweeters. It can also be used to reduce the huge signal (unwanted freq) to avoid frying tweeters with different / lower freqs.Help me out, passive inline crossover?
Thanks my friend. I will run that by my SA and see if they can have a local shop handle it. Though, I would prefer, if possible, to have the dealership handle any required disassembly of the STO.There is a factory amp with one huge signal (essentially one plug), and we use the passive crossover to split the huge signal into two or more signals to go into the tweeters. It can also be used to reduce the huge signal (unwanted freq) to avoid frying tweeters with different / lower freqs.
I think maybe just bring the STO to an audio shop since the dealer isn't exactly an expert in installing audio systems. It's just a straight out replacement with tiny crossover device. The dealers may outsource the work to their local audio shops which in this case shouldn't be problem.
It’s a small capacitor that comes with the speakers. I tossed it to the side and ran it straight. But after I blew a set of tweeters I looked closer at the factory tweeter and realized there is a small crossover in the tweeter . That acts as a filter for it. In-line meaning it goes inline of the speaker wire , comes with the speakers. . I installed a new set of tweeters with the crossover it came with and it was golden. Again it comes with the speakers. A wire for each speaker that has a small diode/crossover in the wire. This is necessary for the tweeter. The door speaker was fine without it as the factory door speaker doesn’t have one inline or on the speaker itself.Help me out, passive inline crossover?
Give me a holler when your ready. I can easily walk you thru it or bring it over and we can hammer it out real quick. It’s super easy.Thanks my friend. I will run that by my SA and see if they can have a local shop handle it. Though, I would prefer, if possible, to have the dealership handle any required disassembly of the STO.
Same offer stand for oil changes?Or if yo ur local bring it over to my house, we can get it done easy for you
Sure, I do those also, easy. Just 50 fasteners, three panels, 8 drain plugs. LololSame offer stand for oil changes?
