541 - 542 of 542 Posts
Discussion Starter #541
The fan from the airco was very unbalanced, everything was shaking. I took it apart and I think t was dropped at some time. The motor is Bosch part 0 130 701010 and no longer available. But Saab 900 OEM nr 8337859 is an exact fit. Bosch nr is 0 130 701122. It is used as fan for the engine cooling. Draws 6 amp without fan, the same as the original.I put it in and now its fine! The fan motor for the cabin heating is the same.
GRS Paul.
Discussion Starter #542
I covered some 550km now and today I retightened the head nuts. Removed the carbs and the cam covers, bank 1 is no problem, for bank 2 I opened the service opening behind the back seat, the opening gives you easy acces to the head nuts, see the pics. After that I checked the valve clearance, one valve is a little bit to narrow. What tool do you need to press down the bucket? Anyone a description or picture? Is it FIAT?
Thank you!
GRS Paul.
