1 - 5 of 5 Posts
Fabspeed Lamborghini Urus Sport Catalytic Converters replace the restrictive factory cats with high-performance German-imported 200-cell HJS catalytic converters for significantly improved performance and sound. The Urus's factory cat-back exhaust is essentially a straight pipe when the valves are open so the only way to gain more sound and power is to change out the factory catalytic converters. HJS Sport Cats flow extremely well, flowing at 93 - 95% the rate of a straight pipe. Fabspeed Motorsport invested a lot of time and resources into developing the best possible downpipes and we're now proud to offer you this latest and greatest solution. Fabspeed Motorsport is the world's authority for aftermarket Lamborghini performance.
299111
SOUND:
Aside from the factory catalytic converters, the Urus has an extremely free flowing exhaust. So the only way to get more sound out of your Urus is to replace the factory catalytic converters. These Sport Cats will make your Urus sound much more aggressive. Pops, bangs and crackles will be much louder and sharper. However, there is no interior drone whatsoever.
POWER:
Get incredible power gains from your Urus with these Sport Cats. We saw max gains of 43 whp and 60 ft/lbs of torque. These Gains are carried throughout the entire RPM range for power you can feel in the seat of your pants. Peak power is also up 14 whp and a very healthy 46 ft/lbs of torque!
FEATURES:
  • Fits all Lamborghini Urus Vehicles (2018+)
  • The largest catalytic converter that will fit the application
  • German Imported HJS 200 Cell High Flow Catalytic Converters
  • Saves 6 lbs / 2.7 KGs compared to the factory Catalytic Converters
  • Adds 43 whp and 60 ft/lbs of torque
  • The most effective Urus exhaust modification
  • Optimized for maximum performance with NO catalyst generated check engine light, guaranteed
  • Constructed from mandrel bent T304L stainless steel
  • Simple DIY (Do-It-Yourself) bolt-on installation, no cutting or welding required
  • All Fabspeed performance products are backed by the Fabspeed Lifetime Warranty
(Bypass pipes in-stock ready to ship)
1 - 5 of 5 Posts
