Hi,
I have a problem with a 2006 Gallardo manual that I can not get any further. Symptoms:
Car drives normally and then you want to accelerate from low speed, but sometimes the engine chokes and stutters, at that time it also smells like gasoline. If you then take the foot off the pedal and accelerate again or if you switch to a lower gear and then accelerate, it accelerates normal. Sometimes it does not accelerate with full power. Also it does not seem to have the full power in the upper rpm range.
No error in the control unit
What has already been exchanged:
both gasoline pumps
both fuel pressure regulator
both fuel filters
air pressure sensor
all sparks
all ignition coils
battery
both catalysts
I would really appreciate help
both gasoline pumps
both fuel filters
air pressure sensor
all sparks
all ignition coils
battery
both catalysts
