1 - 2 of 2 Posts
Hello Fellow Gallardo Spyder owners,
I have a leaking cylinder in my soft top. I plan to send all the cylinders out to Top Hydraulics for rebuild. They have a rather informative video on their site on how to remove the top and replace the cylinders. The video shows four bolts on either side that secure the top. I have removed three per side but the last two don’t fit past the framing of the top. Has anyone been through this and do you have any hints or advice. Thanks in advance for your help.
Tony
Discussion Starter · #2 ·
Update, you do not need to remove the bolt at the top and furthest to the back of the car. There is a hidden bolt around the center area of the assembly. Bend over and look inside the frame and you will see it.
1 - 2 of 2 Posts
