Hi guys I am stuck and need some guidance, with already great help from Ag02M5 and Fredapied, these guys made my first ownership issues less painful then trying to deal with it on my own. I have pulled on them too much and they need a break from my 1000 questions 😁 I need to expand to the masses and hope someone had a similar issue.
So I removed aftermarket radio and installed oem Headunit, everything worked except camera.
Tested camera module, found constant 6v at trigger but buttons had no effect and then tested video on external tv, image appeared.
On the Headunit, I attached the RFSL wire, and turned key on, camera image appears, but won't come off, it's stuck on reverse camera view and I cannot operate other functions of radio.
I disconnect the rfsl wire and radio goes back to operating without reverse buttons (r button and reverse view button) not turning on camera.
I removed the switch on the console button, but camera still on, Fred thinks my R button is pressed in more then normal. Not sure how to remove that lower dash panel to investigate if maybe the button is pressed just enough to keep trigger wire for camera on but not enough to switch gear to reverse.
If there is no obvious cause, I think I might turn the console camera button into a direct switch to rfsl wire, not sure if I need a relay to do this but I wouldn't mind pressing that button to reverse view at any point.
Any tips on how to wire that console button to the rfsl wire, sorry I'm not strong in electronics but willing to try.
Thanks
Cp
Thanks
Cp
