Removing transmission
863 5
Got the engine out of my 92’ tonight.
Trying to separate the transmission from the engine, I got all the bell housing nuts off, and got it +1/2” clear now, but seem stuck on one of the spline axles or something else..?
Wondering if there is any snap rings or the like I need to get off too?
Clutch bearing axle can stay on, right?
Checking in, before I simply apply more force…
Tire Automotive tire Tread Wood Automotive wheel system
Reactions: AngelOfMurci
· Registered
yes, the bearing is connected to the preasure plate. So you can release the circle-spring in the picture above, or simply remove the lever for the clutch slave on the out side of the transmission, and it will slide right out.
