1 - 12 of 12 Posts
Hi,
My car Huracan lp580-2 2016 , when I run ON the power Steering not working!
Gauge Font Measuring instrument Auto part Circle
Did you check the fluid level?
Do you have a leak?
Does the power steering pump turn over?
Do you have a leak?
From where i can check fluid level?
No i do not have leak
What you mean power steering pump turn over?
The dashboard show this message:
Do not drive vehicle:
steering defective
Automotive design Font Vehicle Automotive exterior Motor vehicle
if I remove battery for minimum minutes and connect it again ,they have any side effect?
From your replies, you are not mechanically inclined. Definitely time to go to the dealer. For sure.
sounds like a serious issue, i’d recommend you take it to the lambirghini dealership (Lamborghini Doha) to at least get assessed.
And don't forget to come back and close the loop with us so we can also learn from what happened to you!
Thanks!
Discussion Starter · #12 ·
I take it to dealer , they told me the steering system failure and must be change.
I do not know how came failure ! what the reason.
The Steering system failure without any reason,How its came like this?
the car almost new with less KM with out any accident or bad use
Steering power port code: 4S1423050K
Thanks!
1 - 12 of 12 Posts
