1 - 4 of 4 Posts
Hello Lee,
Does euro-spares not have used ones far cheaper ?
If not you can do is build up weld on the teeth and reshape them... but that is likely expensive
Possibly Lambo parts has the "ring" which is heat shrunk on the flywheel...or alternatively see what other flywheels are the same size and have a similar starter gear configuration...
Paul
At this time i don’t know how many teeth are necessary, but look for something like that.....
But it needs some work an after mounting a good alignment....
I recollect that a P-250 clutch disc is the same as an old MB 240...so possibly the "ring gear" might work. A friend in Connecticut mentioned that a P-111 owner has a broken ring gear...it must be a case of "old metal"...I don't ever remember seeing this 30 years ago...:oops:
Paul
1 - 4 of 4 Posts
