Hi there,
had that "double banana" (spoiler fault error message) light up after some minutes of driving and finally wanted to find out why. So i removed the inside bonnet plastic trim, disconnected the hydraulic struts, removed the motor and the silver tubes and disconnected the spoiler. After i had everything removed, i removed the motor from that black plate that holds it to finally see if it works manually. The manual operation did not work and so i had a deeper look in the area where the gear hits these "drivelines" (sorry for my bad english, did not know the correct word for it) and saw that one of these lines is missing / had snapped (passenger side) - the upper one as you can maybe see in the first pic! think it broke in the past... the upper one was not visible and the other one was not moving.
Do you have any expierience in repairing that thing or should i just...
Thanks a lot for some hints, have a safe and spirited drive and best greetings!
I also found Gallardo Spoiler Drive Kit in the forum. So maybe someone knows someone that has the cables or some parts - i would appreciate it!!!
- replace all of it
- think about installaing an SL wing
