1 - 13 of 13 Posts
· Vendor
Reactions: 7.62x39
· Registered
Looks great! I made one similar. The oil filter is not supposed to be cranked down tightly, just snugged to the stop, so a plastic wrench is fine. I only hand tighten anyway. You can make the handle shorter to help with access. The filleting helps with handle strength.
293951
Reactions: 7.62x39
· Registered
how thick did u print yours? I printed mines 4mm thick. With cheap pla. I overtighted my oil filter so it’s defiantly going to be put to the test 😂
· Registered
Code:
looks like huracan uses 32mm socket to remove oil filter. Different housing/filter
I don't think you need this tool for the huracan. You can get the regular oil filter housing sold at Kragen. I use the Mercedes one w/ the bolts on the side to hold it in place and loosen the housing.
· Registered
Anyone willing to share their files so other folks can 3dprint? This is awesome
The site won't allow me to upload the files due to filetype. Perhaps I can email it to you if you pm me with your email.
1 - 13 of 13 Posts
