Wrong meter, thats oil temp.
Ok, thanks for this reply. Ive just never ever seen a stock car have this behaviour so i thought theres something broken since i also had the coolant smell inside the cabin before tightening hose clamps under the front compartment.It will fluctuate because there is a thermostat open temperature that is somewhere around 80 and the fans kick on at around 90. If you are driving with the A/C on the temperature will stay more consistent since the fans will be running. I have never seen mine go down to 60 or even below 80 after it was warmed up going that low would mean your thermostat is not working properly. Mine has 65k miles.
Yes I think a lot of cars do not really report the actual Temperature when in the normal operating range. My 2010 Tahoe that I have owned since new and has 244k miles I have never seen the needle move once it is warmed up, my 2021 Tahoe is the same way. That really isn't possible unless the fans are always on but my guess is car companies would rather make a the "normal spot" to be a pretty wide range of temperature to not get so many questions.Ok, thanks for this reply. Ive just never ever seen a stock car have this behaviour so i thought theres something broken since i also had the coolant smell inside the cabin before tightening hose clamps under the front compartment.
First drive ever since i bought the car mid winter. It has straight pipe exhaust and just drove it today but didnt have the same temp drop as earlier, might have been a electrical misfunction?agreed w/ Rob. Mine the temp ranges if stop and go traffic it jumps to 95ish maybe.... but average is 89 or so. Never has gone to 60's once it's warm.
When did you do a coolant flush? You may want to do that to put your mind at ease to make sure it's up to par.
