1 - 20 of 74 Posts
I am pleased to report that everything works.. Just fired her up.
Coils, Dist Cap, Rotor...made for mid-90's Jag V12.
SI LAMBO said:
Frank,
Ready for a RESTORATION?
LOL
Still waiting for my car. I'll be in Chicago when it returns next week. :(
I know it's been some time for you... Post pix of the final product when you get her... BTW what did you do with the nose..did u leave the skateboard wheels on?
Phone numbers for Napa parts
I need phone numbers for a coil for my diablo...Anyone tell me Napa parts phone number.. i am in england so i cant call a freephone number it needs a state code...
Carlo
Discussion Starter · #14 ·
Carolo - NAPA is a large franchise chain of stores here in the US.
I went to a local NAPA...it's a special order which means 2 days wait. I told them to overnight, which they did.
Now what you have to do is call a local store, get it, then ask if they can send it to you in the UK. You'll have to prepay with credit card, I assume.
You can find a store on their web, but no online ordering..the one I used in FL is 954-983-3150.
If it does not work out for you, let me know. If you have pay-pal or prepay with a check to me I'll order it and ship it DHL/FED-Ex to you.
PM me if you need help.
Hi Frank
Thank you.. Dam coils.. I was talking to lamborghini guru Del Hopkins about the coils failing and he said there is a diode that you put in line from the ecu that helps prevent this happening.
I will see how i get on and let you know.
Best Regards
Carlo
I've heard of this Mod before....the thing that makes no sense about the Diode Treatment is that the Computers (LIE's) run on 9 volts & 1.5 amps.
This is in no way enough to back feed a coil into default.
Additionally, not one of these gurus has ever shown that their Modded systems lasts longer than the factory set-up!
Sounds good over the phone, but until I can see PROOF...I'll just keep smiling!!
Discussion Starter · #17 ·
Let me post a few comments now that I've installed everything:
First, understand that my car is a 92 with 8K miles. Plugs, coils, dist, all original and never changed from new. In other words 13 years old. Installed Tubi and stright pop and got some louds pops, typical of no back pressure. Noticed high smell of exhuast and EGA showed high HC, so I thought I try simple tune up.
There was mention by Lambo vendors the NAPA stuff would not work. Yesterday I did a car show and "ran" the car for the first time. BTW I also went to K&N with SP air intake kit.
1. Car runs incredibley well.
2. Idles so smooth you can balance a nickle on the hood
3. The "pop" on de-acceleration are all but gone, barely hear them.
4. When leaving the show, from a 30mph roll, I punched it and spun the wheels and the car went almost sideways on me (good reason for vt). I had a freind with a Ferrari behind me who can witness.
Now as for the coils:
They work very well. A bit of work to change them because not easy to remove. The air ducts in front and behind them should be removed first.
I have read in several threads that early Diablo's had a ground (UK=earth) problem due to paint on frame. When you remove the coils, there is a bracket that mounts to the frame with 2 bolts. I removed the bracket and sanded the paint off of it and off the part of the frame where it bolts on. Before installing the new coils I used dielectric cream on the areas also to prevent arcing (sp). I had a slight problem on final re-assembly fitting the forward air tube back in because it was hitting on the coil. Don't know if it was me, or the coil may have just been slightly larger. The bottom of this air tube has a hole in it to blow fresh air over the coils. I made the hole slightly larger and the air tube went back on with no problem.
Here's a pix of the intakes:
All the early car in the u.k had the diode conversion if the coils failed by Del hopkins while he was at Lamborghini.. Unfortanatly my car has not.. Ive just replaced the coil with a intermotor coil that is the same and i have no spark from the yellow side..
1 - 20 of 74 Posts
