1 - 8 of 8 Posts
Hi I have just both my second lamborghini but my first Murcielago LP640 MY2007
only one problem. When I hit the trottle hard the car goes to the left and when I let lose of the gas it goes to the right.
very strange and definitly not good.
I checked the suspension.
my right front shock absorber has a small leak from the lift system. But don't think it is this. cars that have a not working lift system are driving also good.
but suspension is looking good and we can not find anything.
has any body a idea or had this before?
Have you had the alignment checked?
2005 Lamborghini Murcielago Roadster & 2007 Lamborghini Murcielago LP640 Coupe
I鈥檝e experienced the same with mine. My rear ended swings left when I really take offf. Especially in second gear. I haven鈥檛 had time to check alignment.
I did switch from aftermarket 19s and 20s to stock Hermera鈥檚. I鈥檝e not yet taken out my murc to see if the correct wheels and new set of tires fixed it
Please let me know if you figure it out I鈥檒l do the same
Tire pressures can certainly cause that.
Problem solved
I got the alignment corrected and now the murc tracks straight. No more pulling to left under heavy load.
1 - 8 of 8 Posts
