USED for approximately 1000 miles - 99% highway. This set is the original development set of coilovers for the Murcielago.
These are in good working condition and set to the lowest ride height setting (1.5 finger gap on 2WD / 1 finger gap on AWD).
Avoid the delay of having a new system built and lower price point.
Zip ties are holding bushings together - remove before installation.
Reid Performance Coilovers for Murcielago. A Murcielago has never felt so stable.
Replace 12+ year old suspension and improve your Murci’s handling and ride quality with modern technology. Height adjustment settings from stock ride height and can be adjusted lower than the stock units.
The perfect choice for street driving with a more controlled feel and ability to dial in the suspension to your specific needs. Featuring easily accessible damper adjustment knobs and separately adjustable ride height, the makes adjusting and maintaining your Murcielago coilover easier than ever. Locking rings keep all adjustments locked in and ready for precise predictable feedback in any scenario. RP coilovers provide a strong, complete and attractive coilover system at a lower cost than factory replacements
General:
  • Penske Shocks with Hyperco Springs
  • Two-way shock design | independently adjust compression and rebound
  • 45 levels of compression and rebound allow fine tuning
  • Ride height control from coilover body height and spring perches
  • Heim joint bushings
  • Rebuildable
  • Hard Chromed Steel Shaft Provides Strength and Low Friction
  • Durable Aluminum Components are Lightweight
  • Plug & Play Nose Lift
  • Easy Installation
Note: 2002-2004 Murcielago require '05+ style nose lift hose connections.
