Set of ADV.1 Trackspec wheels 20x13" rear and 19x8.5" front.
All straight, but in need of a refurb.
Direct fit on the first gen Murcielago. I had them fitted to my LP640 which requires removal of the small bolts that hold the discs to the hub. This has no negative effect on anything if you use a wheel stud conversion as I did. If you use standard wheel bolts you have to get the disc in the right place to line up the bolts with the holes in the hubs. It's no drama.
£3k as is. £3.5k refurbed.
Collected from Birmingham UK, or I can send with a courier at purchasers cost and risk.
Thanks
Phil
