Over the years I have read all kinds of figures of how much weight is saved when going 2WD with a Murcielago. The numbers I have read are anywhere from 100-300 lbs. Reid Performance quotes on their website a weight savings of 150 lbs.
Today I broke out the scale and weighed all of the pieces that comes OFF of the car when you go 2WD. Remember any pieces of a 2WD conversion like a transmission mount and stub axles have their own weight that is then added back on.
Here is the list:
Prop Shaft - 5.73 lbs
Torque Tube - 10.2 lbs
Half-shaft #1 - 14.65 lbs
Half-shaft #2 - 15.00 lbs
Differential - 57.2 lbs (includes diff oil)
All Hardware - 3.37 lbs (includes all bolts, and front differential rubber mounts)
Total: 106.15 lbs
Bear in mind this is for a manual transmission car that has a longer torque tube and prop shaft. As such these numbers represent the maximum amount of weight that will come off again BEFORE you put back a forward transmission mount and stub axles. I do not have weights for the Reid Performance parts but it is fair to say that the NET weight savings is somewhere closer to 90-95 lbs. Not insignificant but a decent amount less than is generally quoted.
Here is the list:
Total: 106.15 lbs
