1 - 5 of 5 Posts
2019 huracan performante 2008 murcielago lp640
Has anyone experienced their murci popping into neutral on a high Rev gear change? It's happened twice. I first thought it was the clutch so I drove it immediately to the dealer who told me my clutch still has life. They tested it and nothing.
It happened again when I left the dealer ! Would like to know if anyone else has experienced this and what the remedy was ?
Is it gated or egear? My gated Gallardo did that a couple of times before the cable bush gave up.. if it’s egear then try checking the fluid. If not, you may have to dig deeper...
its an e-gear.. fluids checked after incident.
You might have a system pressure issues. You might be losing pressure. When there is not enough pressure in the system, the default is Neutral which is a good thing so you don't damage the transmission. Loss of pressure can be caused by a leak. You might have a bad accumulator or a bad actuator. Have them check the pressure.
If it turns out to be a bad actuator, we can rebuild them.
Had the very same issue a couple years ago. Replaced the accumutator and all is perfect. Would only show the issue on wot shift.
1 - 5 of 5 Posts
