1 - 12 of 12 Posts
I think it is time to go over passenger car automotive engine oils in detail. I will be writing several articles to be published soon so I will try to get some of it out here. I feel this is a very general topic for all car owners on this board.
This is a very difficult topic to comprehend. Everybody including good mechanics think they are experts in this field but few understand engine oils. Most of what I hear is the opposite of the truth. It is however easy to see how people get mixed up as there is always some truth to the misconception.
Please forgive me if I am too wordy or even verbose at times. I will be redundant for certain. This will be in areas that people have to hear things over and over again to get it right. Some will never be able to understand these concepts unfortunately. I base my thoughts on those whom I have been listening to in various automotive chat rooms and discussion with mechanics. I will try to minimize technical terms and be somewhat vague rather than exact. I will round and average numbers to make the point simple rather than mathematically exact. Thickness has the same meaning as viscosity. Viscosity is a measure of the resistance of a fluid (liquid or gas) to flow. Fluids with high viscosity, such as molasses, flow more slowly than those with low viscosity, such as water.
The greatest confusion is because of the way motor oils are labeled. It is an old system and is confusing to many people. I know the person is confused when they say that a 0W-30 oil is too thin for their engine because the old manual says to use 10W-30. This is wrong.
More confusion occurs because people think in terms of the oil thinning when it gets hot. They think this thinning with heat is the problem with motor oil. It would be more correct to think that oil thickens when it cools to room temperature and THIS is the problem. In fact this is the problem. It is said that 90 percent of engine wear occurs at startup. If we are interested in engine longevity then we should concentrate our attention at reducing engine wear at startup.
Oils are chosen by the manufacturer to give the right thickness at the normal operating temperature of the engine. I will say this average oil temperature is 212 F, the boiling point of water. On the track that temperature is up to 302F. It is important to realize that these are two different operating environments and require different oils.
I will discuss driving around town first. Everything I say will be based on these conditions. At a later time I will discuss track conditions. Everything I say will be as accurate as possible without looking everything up and footnoting. I am trying to be general, not ultra specific.
One thing that is no longer important is the ambient temperature. Older automotive owner manuals often recommended one oil for the summer and another for the winter. This is still necessary for air cooled engines but is no longer a consideration in pressurized water cooled engines. These engine blocks are kept at around 212 F all year round. The oil is around the same temperature as well. This allows for a single weight oil all year round. Again, this is not the same as on the track where the coolant temperature is slightly higher and the oil temperature is much higher.
Please forget those numbers on the oil can. They really should be letters as AW-M, BW-N or CW-P. The fact that we are dealing with a system of numbers on the can makes people think that they represent the viscosity of the oil inside the can. The problem is that the viscosity of oil varies with its temperature. A “30” weight oil has a viscosity of 3 at 302 F ( 150 C ) and thickens to 10 at 212 F ( 100 C ). It further thickens to a viscosity of 100 at 104 F ( 40 C ) and is too thick to measure at the freezing point of 32 F ( 0 C ).
30 weight oil:
Temperature ( F ) : Thickness
302 : 3
212 : 10
104 : 100
32 : 250 (rough estimate)
The automotive designers usually call for their engines to run at 212 F oil and water temperature with an oil thickness of 10. This is the viscosity of the oil, not the weight as labeled on the oil can. I want to stay away from those numbers as they are confusing. We are talking about oil thickness, not oil can labeling. This will be discussed later. Forget the numbers on that oil can for now. We are only discussing the thickness of the oil that the engine requires during normal operating conditions.
The engine is designed to run at 212 F at all external temperatures, Alaska to Florida. You can get in your car in Florida in September and drive zig-zag to Alaska arriving in November. The best thing for your engine would be that it was never turned off, you simply kept driving day and night. The oil thickness was uniform, it was always 10. In a perfect world the oil thickness would be 10 at all times and all temperatures.
If the thickness of oil was 10 when you got in your car in the morning and 10 while driving it would be perfect. You would not have to warm up your engine. You could just get in the car and step on the gas. There would be little wear and tear on you engine. Unfortunately the world is not perfect.
The night before when you drove home from work the car was up the the correct operating temperature and the oil was the correct thickness, 10. Over night the engine cooled to room temperature and the oil thickened. It is 75 F in the morning now (I do live in Florida). The oil thickness is now around 150. It is too thick to lubricate an engine designed to run with an oil having a thickness of 10.
see next page---
Discussion Starter · #2 ·
It is time to introduce the concept of lubrication. Most believe that pressure = lubrication. This is false. Flow = lubrication. If pressure was the thing that somehow lubricated your engine then we would all be using 90 weight oil. Lubrication is used to separate moving parts, to keep them from touching. There is a one to one relationship between flow and separation. If you double the flow you will double the separation pressure in a bearing. The pressure at the bearing entrance is irrelevant.
In fact the relationship between pressure and flow is in opposition. If you change your oil to a thicker formula the pressure will go up. It goes up because the resistance to flow is greater and in fact the flow must go down in order for the pressure to go up. They are inversely related. Conversely if you choose a thinner oil then the pressure will go down. This can only occur if the flow has increased.
It seems then that we should all be using the thinnest oil money can buy. This is partly true. Let me use my 575 Ferrari Maranello as an example. I drive this car around town. The manual of this car states the target pressure is 75 PSI at 6,000 RPM. The gold standard is that all engines should have a pressure of 10 PSI for every 1,000 RPM of operation, not more, not less. After all, you do need some pressure to move that oil along, but only enough pressure, not more. More pressure is not better, it can only result from the impedance of oil flow. Remember that oil flow is the only thing that does the lubricating.
Note that Ferrari is not saying what thickness of oil to use. That can only be determined by experimentation. My engine oil temperature is running around 185 F as I drive around town. I have found that the thinnest oil I can buy that is SAE certified is Mobil 1’s thinnest oil. Even with this oil I get 80 PSI at 2,000 RPM. It is too thick for my application yet it is the thinnest oil money can buy. If I was on a hot Florida track in mid-summer the oil temperature would probably get up to 302 F. I will guess that the pressure would only be 40 PSI at 6,000 RPM. The oil I am using would not meet the requirement of 75 PSI at 6,000 RPM from Ferrari. I would have to choose a thicker oil for this racing situation. The oil I use now would be too thin at that very high temperature. (This is only partly true. Higher RPM running engines use thinner and thinner oils to get more and more flow. I will discuss this later).
High flow does more than lubricate. It is one of the things used to cool the hottest parts of your engine, the piston and valve areas. This cooling effect is as important as lubrication in your engine. If your engine is running hot use a thinner oil. The flow will increase and so will the cooling. This is even more important in the racing condition.
Let us go back to the Ferrari manual. My older 550 Maranello only specified 5W-40 Shell Helix Ultra as the oil to use in all conditions. This is a car for racing. As it turns out Ferrari now recognizes that not every owner races their cars. The newer 575 manual now states to use 0W-40 for around town situations even though Shell does not make this oil in the Helix Ultra formulation at this writing. They also recommend the 5W-40 by Shell if you insist on the Shell product.
Ferrari recommends Helix Ultra Racing 10W-60 “for hot climate conditions racing type driving on tracks”. Note that they now realize the difference between the daily urban driver like me and the very different racing situation. These are widely different circumstances. I want to emphasize that they only want you to use this oil while racing in “hot climate conditions”. If you are racing in Watkins Glen up north use the 5W-40. If you are racing in Sebring in the middle of the Florida summer use the 10W-60. Around town in any climate, use the 0W-40.
It is time to dispel the notion that 0W-30 oil is too thin when our manual calls for 10W-30. A 0W-30 is always the better choice, always. The 0W-30 is not thinner. It is the same thickness as the 10W-30 at operating temperatures. The difference is when you turn your engine off for the night. Both oils thicken over the evening and night. They both had a thickness, a viscosity of 10 when you got home and turned your engine off. That was the perfect thickness for engine operation.
As cooling occurs and you wake up ready to go back to work the next day the oils have gotten too thick for you engine to lubricate properly. It is 75 F outside this morning. One oil thickened to a viscosity of say 90. The other thickened to a viscosity of 40. Both are too thick in the morning at startup. But 40 is better than 90. Your engine wants the oil to have a thickness of 10 to work properly. You are better off starting with the viscosity of 40 than the honey - like oil with a viscosity of 90.
I repeat: More confusion occurs because people think in terms of the oil thinning when it gets hot. They think this thinning with heat is the problem with motor oil. It would be more correct to think that oil thickens when it cools to room temperature and THIS is the problem. In fact this is the problem.
This is the end of lesson number one.
Topics to follow: Mineral verse synthetic oils, oil additives, SAE ratings, racing oils, traffic conditions and the environment, misconceptions.
aehaas
Many thanks for taking such trouble with that posting - really interesting, I learnt a lot.
I use Mobil 1 0W 40 in my Aston Vanquish, they only recommend this oil as the engine does run very hot - now I know why!
The weather here in the UK is not overly similar to Florida and I regularly have to start a cold engine (when the temperature is 5C) - I guess there's nothing else one can do to protect the engine other than using the correct grades of oil...
Dr Haas: In the Owners handbook it shows the oil spec for my 99 Diablo to be
AGIP Sint 2000 SAE 10W/40 or 10W/50 API-SF. They attached an ammendment (new page) that now shows the oil spec to be SAE 5W/40
API-SJ/CF. Can you tell me what this change really indicates? Thanks Very Much!
Discussion Starter · #11 ·
That attachment indicates they want you to use only a 40 weight oil and that oil should have less thickening at startup. They also indicate to use an SJ rated oil. The current rating is SL and the SM is coming out. These new ratings indicate better performance in every single catagory they measure.
Never use something rated SJ when the same viscosity 5W-40 is out in an SL rating. The actual brand of oil is virtually unimportant. Though it should be a synthetic.
I recommend you use the 0W-40 Mobil 1. When you read the remaining articles you will see why.
aehaas
1 - 12 of 12 Posts
