1 - 5 of 5 Posts
Hi everyone. Should the rear window be operable at any point? Does the top position (full up or full down) make a difference? Or handbrake on/off?
My rear windows drops and raises during top operations - which is as per normal.
But I can't seem to be able to manually operate it via the switch - it seems to only work intermittently so I am wondering if the switch is the problematic or if there are certain conditions that needs to be met before the rear window will operate.
Cheers.
Correct, anytime the top is fully up or fully down, but that switch is a momentary cycle switch, so sometimes you have to press it twice for it to go in the other direction. Otherwise, yes, it should work all the time as long as those conditions are met.
1 - 5 of 5 Posts
