Hi guys, looking to buy a 2015 Aventador and dealer sent me the following reading and error codes. Can someone explain to me what these codes mean?
Address: 0074 System name: 74 - Running gear control Protocol variant: KWP2000/TP20 (Ereignisse: 1)
Address: 0019 System name: 19 - Data bus diagnostic interface with Most Protocol variant: KWP2000/TP20 (Ereignisse: 4)
Address: 006B System name: 6B - Aerodynamic control unit Protocol variant: KWP2000/TP20 (Ereignisse: 1)
Address: 005F System name: 5F - Information electronics 1 Protocol variant: KWP2000/TP20 (Ereignisse: 1)
SPG_47_A_____1_1112_88_Spannung_Starterbatterie_00088Evaluation factor: -
Error list:
Control unit addressError
006BVAG00070: Voltage starter battery
SYS_47_J533_____2_1211_88_antrieb_00088Evaluation factor: -
Error list:
0019VAG01314: Engine Control Module
J533_47_27_____8_1211_88_ruhestrom_00088Evaluation factor: -
Error list:
0019VAG02256: Static current
R199_47_91_____1_1011_88_R199_Audioleitung_00088Evaluation factor: -
Error list:
005FVAG02612: Audio wire adapter set
SL #7007
Are you not buying from a Lambo dealer? Why wouldn’t these be fixed prior to purchase? Lambo or not, I wouldn’t buy any car from a dealership that has preexisting issues…..
ECM errors are usually not a good sign, try to get the full error codes and look for anything related to the gauge cluster. There's LP700's floating around that I suspect are been rolled back.
Be extra careful in this market, the market is hot so a lot of buyers are buying cars without proper PPI's so there's a lot of shady cars entering the market.
ECM error and all the other ones attached to it is telling me to run. Even with a good PPI done we are all humans and will miss one thing that may cost you an arm and a leg. Unless you buy a bumper to bumper warranty and it's covering every single thing minus the general items I wouldn't touch this car.
Reactions: Cliff.1620
