LeMans Blu Gallardo
7554 Views 67 Replies 17 Participants Last post by  FontusBluG
I'm looking at an 08 Gallardo Spyder in LeMans Blu. Supposedly that color is extremely rare and I would like to know exactly how many where shipped to the US. Is there a website I can go to to find that info?
Thanks in advance.
41 - 60 of 68 Posts
All the speedos are miles off. 10% against a GPS speed. If you sit at 100mph you're really only doing 90.
Congrats Mycoolsteel! Beautiful car, and I love the color! Glad to hear that you were able to negotiate a good deal. Have fun on the trip back home.....I'm sure you're having a blast!
Made it to Tuscon last night, we spent about 6 hrs on the road. We got a late start but I think we are well rested and ready to go.
The car is doing great except I think my mph is over by about 7, any ideas on how to fix or even what would cause it?
I was so nervous to leave it outside at the Marriott last night..... but I was more worried about falling asleep driving it. I checked on it several times through the night (asked for a window room) and first thing this morning and everything is fine!
Only 12hrs left......
Looking good! :)
As mentioned by others, the speedo error seems to be a common one. So far, I haven't heard of a proper fix for this issue...if there is one, it would be great to know...
IIRC, I remember reading somewhere that Federal law required speedometers to be within a 5% accuracy? Plus or minus 2.5% from the true reading? Mycoolsteel, I assume that your tires are the original sizes? If not, this could potentially be causing the issue?
There has got to be some kind of device out there that allows us to calibrate our speedos???
Thanks to everyone for the advice and compliments.
Great pics lamboperth. I'll be checking that app out. I downloaded three different ones yesterday to make sure it was the car and not the apps.
Finally made it home last night at about 9pm central time. It was a brutal 12 hrs in it.
See less See more
Factory tech doesn't seem to know about any issues and if they can be calibrated?!
Are all our cars off on the speedometer reading? And if so why?
And how does it affect our odometers?
Just read earlier in the thread.
_________________________________________________________________
Paul1,
Some European countries have a stiff fine for auto manufacturers if the speedometer reads slower than actual speed. So I'm guessing Lamborghini was extra cautious in building in a safety margin in their speedo calibration. When I was at Ford, our spec was actual speed -0 mph/+5 mph not a percentage error. But then we weren't selling 200 MPH cars either. The error on my 2014 Lincoln MKZ is right around +1 mph @ 70 mph so it seems like Ford is still using the same tolerance band.
Use a V-box if you want actual mph or test the speedo. I think it's pretty spot on in Lambos but if not it can't be too bad. I've used speed trap readings too and things seem to be right spot on for both my LP560-4 UGR TT and LP560-2 Aniversarario all the same. Dunno if same on PreLP or other LPs?
After a little research 10% off on the speedometer seems to be pretty common on pre-lp's for sure. It DOES NOT affect the miles / odometer, that's a "different sensor". Thanks for everyone's input on that. Although of all the threads I read none of them found (or at least posted) a solution so if anyone ever finds one please post here ����
My new concern is the egear pump priming every time I open the door after sitting only overnight 12-14hrs. I read somewhere that could be the sign of a pretty expensive fix.
Once or twice I had to go to reverse before it would go into 1st.......
Added a little Castrol Syntec 5w-40 this morning, $9.99 from Advanced Auto
Signed on some insurance at State Farm today.... get this, it was cheaper if I added Life Insurance. That right there takes the Lamborghini to a whole knew level of Awesome! Lol
The E-gear pump will prime after less than an hour thats perfectly normal.
If it primes for a long time that may be cause for concern but it is normal for it to re-prime unless you hop back in the car ten minutes later.
Not true at all. Sounds like it is operating exactly as it should!~
"My new concern is the egear pump priming every time I open the door after sitting only overnight 12-14hrs. I read somewhere that could be the sign of a pretty expensive fix."
Awesome!! That must've been what I was remembering......priming to long. This forum makes Lamborghini ownership so much more enjoyable!
That's great news!! I was really stressing it.....
Anyone else's ever not shift out of neutral into first?
It might have just been not having my foot on the brake, it happened today but fixed itself when I pushed the brake.. not sure if I was pushing it before. I'll be sure and pay close attention to that next time.
If your at a stop light and it's a long light and you take your foot off the brake it will go from the 1-6 shift screen to the RN screen. Depress brake again and shift lever to engage 1st gear once brake depressed the 1-6 shift screen will reappear.
So only pushing the brake will make the 1-6 screen appear or do I need to pull the positive shift lever??? Newbee questions!! Thanks
Brake depressed = 1-6 shift screen then select first year w right shift lever.
41 - 60 of 68 Posts
