1 - 5 of 5 Posts
· Registered
I just looked under my Diablo and found a slight leak of gearbox oil. It is coming straight out of the speedo sendor on the gearbox has anyone head this problem before.. Everthing is tight but it still seems to be letting a little drop out..
Thanks
Carlo
· Registered
Hi co-member,
Unless there is a gasket to replace first.....
...one could try removing the sender (a special socket may be required) and then wrap some white telflon (sp) tape around the threads and reinstall.
I personally would not use any glue or sealant.
1 - 5 of 5 Posts
