Hi All,
I have a 04 Gallardo. Ive had it for 5 months and its been running a dream....
The other day I opened the garage and once I got the car out I found a small stain on the floor, obviously fluid of some kind, probably 8 inches wide.
It seems to be coming from the mid-rear part of the car, front of the engine side.
Now, I've tried to do my research and I've come to the conclusion it could be coolant. I've checked the over-fill tank and it is looking lower than normal.
Temp in the UK has only dropped to 11/12degrees C so could this be a cause of the leak?
Any advice or comments welcomed. I'm also not 100% what coolant to top up with, as the manual says: AGIP ECO PERMANENT.
I've also read about hose clips coming loose and different temperatures causing pipes to change etc, so could it be this?
Thanks
Thanks
