Larry's (Lorrenzo's) Tip & Technique
3613 Views 8 Replies 5 Participants Last post by  raymond
Reference:
Fact:Early Lambo V8's had porous castings.
Use this potion to anerobically seal the pores.
It is usually only available to commercial accounts, Cost Approx $160/ltr.
1 - 9 of 9 Posts
· Registered
Larry can you post the name and possible contacts for the product. I cannot really read it from the one pic. Thanks,
David
· Registered
Larry could you tell us a little more about the product and how to use it?
I'm doing my head gasket on the countach and want to threat the heads with it.
· Premium Member
The loctite part # 17497 - 1 Litre loctite 990 IMPREGNATION SEALANT.
A nice description I read was:
"Years ago new castings were pressure tested for porosity prior to machine work was started. Porous castings were junked prior to machining. Today, porosities are repaired using Loctite 990 which is surface applied and cures at room temperatures. 990 can seal a porosity to the pressure rating of the parent metal. Factory castings are dipped and cured using Loctite Resinol wicking type porosity stop. One type cures at 194F degrees and one cures at room temperature. The porosities are rectified for a lifetime. Aluminum is the most prone to porosity."
· Registered
I can confirm that this product is fantastic. A friend of mine used it on his 1967 P400 Miura and not a drop of oil comes through the castings anymore.
I'm not sure if Loctite still makes this stuff, but Hernon makes a similar product that shows that it is equivalent to Loctite 990. Their product is called: HPS 990. I notice they also have higher rated 1000 and 1100 version as well.
http://www.adhesive-sealant.com/categories/hps.htm
Amazing stuff.
Mike
· Registered
· Registered
Any idea where I can get this stuff?
I found that Hernan gives the following replacement for Loctite:
http://www.hernonmfg.com/crossref.htm
Loctite 537 PMS-10, 539 PMS-10E <-> Hernon HPS 990 Anaerobic Porosity Seal.
Loctite 541 PMS-90E <-> Hernon HPS 991 Heat Cure Porosity Seal.
I also would like to know where you put it onto the block, inside/outside or both?
My valve cover leaks through the Aluminium and I'd like to seal it, if anybody could organize one of these two 990 products I'd be happy.
· Registered
Raymond,
How can I help you?
I happen to have a 1 litre container remaining.
I found the best way to apply is to gently heat the casting with a MAPP gas torch (an oven will also work nicely). I poured some into the internal water & oil passages, drained & used the residual to coat the outer surfaces.
- Larry
· Registered
Larry can I paypal you for this liter?
Just let me know how much you want with airmail delivery.
1 - 9 of 9 Posts
