1 - 9 of 9 Posts
Power of 10
Gallardo and M5 are both powered by V10s, but which is mightier, and which more fun?
October 2005
BMW M5 v Lamborghini Gallardo
T
welve used to be the magic number. Still
is for those of us with long memories. But while there remains something very special about driving a V12-engined car, the tortured howl of a modern F1 engine has fostered an unrivalled fascination for the V10, and endowed ten-cylinder road cars with a unique cachet. No wonder that despite it being almost a year since we first drove the BMW M5, and more than two since Lamborghini first handed us the keys to a Gallardo, both cars continue to hold us in their thrall.
Parked side-by-side, the M5 and Gallardo make an impressive if rather odd couple, but it's the incongruity that cements the spectacle. That it's the bulky German saloon and not the athletic Italian supercar that has the heftier punch and the (theoretically) greater v-max only serves to ladle a little lunacy over this already improbable, intriguing pair.
Spend enough time with either car and the V10's mystique leads even complete strangers to request that you pop the bonnet. Lift the lid on the M5 and, aside from the sheer size of the motor crammed into the engine bay, it's a bit of a disappointment. It's all too clinical: big, plastic shrouds hide all the interesting bits away, creating an air more suited to a domestic appliance than one of the mightiest normally aspirated production engines ever built. The noise isn't that special either when you start it up: a dry, busy chatter, half-way between a big-capacity turbo-diesel and a petrol engine running a bit low on lubricant. A blip of the throttle hints at pleasures to come, but it still leaves you wondering where the passion and drama is hiding.
You only need look under the Gallardo's engine cover to find it. A lesson in the aesthetics of black crackle finish and crisp machining, the Lamborghini's V10 is what a proper engine should look like. Pipe runs, cables and hoses are proudly on display and add to the sense that this is a living, breathing machine that needs feeding with fluids and air to function.
Twist it into life and the Italian V10 clears its throat with an exuberant snort before finding a fast, blaring idle that hits you right in the guts. Of course, a supercar can get away with these kind of aural histrionics, in fact such a glorious cacophony at tickover is compulsory. And, while you don't expect the M5 to vibrate windowpanes at 50 paces, you can't help thinking BMW has missed a trick by neutering the first few moments of the M5 experience.
Cut to the fast, challenging moorland roads of Lancashire's Trough of Bowland, and the M5 finds its forum. The roads are more suited to an Impreza STi, but the BMW is pulverizingly quick, steam-rollering gradients and piling on speed with utter disdain. The engine has found its voice too, building to a uniquely strident, visceral wail as it pulls to 8000rpm and beyond. At full-chat the M5's V10 is fearsome.
Such raw aggression comes as quite a shock, especially after the sedate, refined manner in which the M5 dispatched the M6 motorway earlier in the day, but the speed and ferocity of the monster M Power saloon is a double-edged sword. Having Roger Green in the Gallardo up front is an excellent incentive, but as our speed increases and the road begins to duck and dive, you get an increasingly insistent feeling that while the V10's up for anything, there's massive momentum at work, and it takes far more out of the M5 than you'd think simply to stop it running away with itself.
While there's an impressive sense of grip and traction when driving the M5 in isolation, following in close company with the Lamborghini is a stark illustration of just how much restraint you have to practise in normal driving, and how little of the V10's 501bhp and 383lb ft you're able to use before cracks start showing in the M5's impressive dynamic facade. At what feels like 7/10ths the M5 has a reassuringly composed feel, but it needs to dig a lot deeper than that when Green squeezes on the Gallardo's throttle with a little more insistence, or pushes just that little bit harder and deeper into a corner on the brakes. Do so and the M5's limits suddenly don't feel so lofty.
Jumping out of the M5 and into the Gallardo is to step into another world. Stripped of the M5's space and well appointed but overwhelmingly normal interior, the Lamborghini is a much more intimate machine. Slung low and squeezed tight between door and transmission tunnel, you feel every buzz and tingle, while the added weight of the steering and the increased interaction of a manual transmission immediately define your role as that of driver rather than awed passenger.
Attacking the same stretch of road, Lamborghini leading, Green now following in the M5, it's easy to see how the Gallardo can toy with the BMW. Its engine, so vocal and energetic, summons greater low-rev and mid-range torque, something that feels all the more impressive in a car that weighs a third of a ton less than the M5
ADVERTISEMENT
. Consequently, when you plant your right foot to the floor the Lamborghini genuinely leaps forwards, while the M5's more highly-strung torque delivery and extra bulk mean it takes an extra few crucial moments to hit its stride.
Granted, once both cars' lungs are full, little separates them in raw pace, that early stolen ground remaining surprisingly constant, the high-revving M5's vivid stampede ensuring it never fully recedes in the Gallardo's mirrors. Until the next corner fills the windscreen, at which point you can drive the Lamborghini so much harder and deeper into the bend and turn in with so much more speed and aggression that despite its best efforts the M5's bulk catches up with it once more, the saloon losing more ground and taking more out of its tyres and brakes.
And then, just to rub it in, as you see the corner open out and your right foot feels for the carpet once more, the Gallardo's superior traction punches you onto the next straight with a vehemence the rear-drive M5 simply can't answer. And that's in the dry.
Does this make the M5 a bad car? Hardly. If you've never experienced what a real supercar is capable of, and you don't have the funds to purchase one, the M5's demented pace and animalistic cry are your passport to new and exotic territory. That it costs half the money, forces the Lamborghini to dig deep to save face, seats four in impressive comfort and possesses more high-tech hardware and electronic driver aids than a whole herd of Lamborghinis only reinforces its fearsome reputation as the world's most accomplished supersaloon.
Ultimately, though, it's physics that defeats the M5. That wailing M Power V10 comes close to challenging a few of old Sir Isaac's Laws, but hurling an 1800kg saloon down the road at supercar-rivalling speed generates such gargantuan quantities of inertia that unleashing the V10's full potential is tantamount to declaring war on the rest of the car. The outcome is inevitable, brakes and tyres succumbing to the onslaught, with deftness and delicacy the early collateral casualties in the battle to contain the M5's rampant performance.
The Gallardo's dynamic focus is its forte, but so too is its ability to juggle civility and savagery on demand. Tractable and manageable through town (even in H-pattern manual spec), when the road opens out and your right foot feels for the floor, it's as sharp as a switchblade. Lithe, low and 300kg lighter, the Gallardo has the traction, poise and agility to put its V10 to full use. It also has the immediacy, intimacy and directness that makes you feel fully part of the process rather than an awestruck passenger, while the chassis, brakes and engine join forces in attacking the road, rather than fighting each other.
The M5 packs an engine every bit the equal of the Lamborghini's, but even M Power's spectacular fireworks can't disguise the fact that while the Gallardo was born great the M5 has had greatness thrust upon it
LOL LOL AhaHahAhaha
"while the Gallardo was born great the M5 has had greatness thrust upon it" - Evo
that pretty much says it all...
isn't the point of the m5 to be an understated performance car that can blow the doors off of most everything else on the road? don't know if you can count it against the bmw that it's not an extroverted car.
in case you guys haven't seen it:
http://www.e90post.com/goodiesforyou/topgear-m5.wmv
yeah, i'm a self-professed bmw whore! but for sheer fun, i'd take a gallardo over an m5 any day.
-james
What persone in there right mind would compare a Beamer to a Lamborghini? Yea maybe its faster but who cares its a Lamborghini. I didnt even read the comparison I only read those if there comparing cars that are close to the same not a supercar and a sedan or coupe Im not sure what the M5 even is.
Settle down, guys.
The article was about two completely different takes on a V10 powered car, not an attempt to say they were similar cars.
On the same theme, a recent German mag compared Gallardo, M6 and Viper. The Lambo beat the pants off the other two in accel and lap times, of course, though the M6 had better terminal speed.
I would rather have my G car, with a pathetic 192mph, than a BMW uber saloon with a theoretical 205mph (if it didn't run out of road first). A point pretty much made by the EVO article.
A 500hp 5 series is still just a 5 series. A Gallardo is a thing of rare beauty and a genuine raging bull. A fast german saloon (sedan), no matter how powerful, is just a fat business man's taxi.
1 - 9 of 9 Posts
