Lamborghini LaRA 6.0
151008 Views 460 Replies 72 Participants Last post by  CarGuysOKC
Hi guys
I was searching the net for a LaRA software for my 07 G and i came cross this software (Lamborghini LaRA 6.0).
Here what i found:
Catalogue type: Diagnostics
Operating system WinXP
Disk amount 1 CD
Price 300 USD
Lamborghini LaRA 6.0 dealer diagnostic tool for cars Lamborghini.
The LaRA-AS system
(Lamborghini "RA" Acquisition System) is a proprietary 32 bit diagnostic system developed for Lamborghini to further enhance and control GFA, LIE and other body control modules.
Lamborghini LaRA 6.0 Functions:
1. ECU Identification (Part number, Software version and status)
2. Erase Fault Memory codes
3. Egear Snap file reading
4. Control Unit Identification (Displays a list of every control unit in the car, including the part number and software version)
5. Setting the ABS/ESP control unit "AirBag" (Gallardo) (Murci and Diablos use the ABS/Airbag separate software and hardware)
6. Setting the A/C control Unit Functions
7. E-gear Snap
8. Actuator testing (Waring lights, Antitheft and door closure, lights, wiper and nozzels test, ESP lock and unloc test, Radio speakers, Navigation speaker, TV Tuner test, Climat control flap test
9. Egear flash programming (Pump bleeding, read and write clutch functions)
10. Transport and normal setting (for transporting vehicle)
11. E-gear PIS valve procedure
12. Gallardo Spyder Soft top calibration
13. Gallardo Spyder and Murci Roadster Roll over protection testing
Late Model Murcielago functions
** The LarAS replaces the LDAS in many functions and includes the following tests
1. Throttle body adaptation
2. Electric Vacuum pump testing
3. Load control valve adaptation
4. Oxygen sensor thrust test
5. Tank bleed valve diagnosis
6. Intake camshaft adjustment solenoid valves diagnosis
7. Exhaust camshaft adjustment solenoid valves diagnosis
8. Diagnosis of the exchange of oxygen sensors downstream of the catalytic converter
9. Diagnosis of the oxygen sensor upstream of the cats
10. Diagnosis of the tank seal (LDP) & Secondary air system
11. Detection of irregular engine ignition
12. Misfire
13. Knocking sensor
14. Lambda oxygen sensor
15. rpm adjustment 7. Throttle body control
16. Exhaust noise reduction valve 9. Special MWB
17. Variable valve timing 11. Compatibility
18. Direct Fuel injection IDS
19. Torque request
20. CAN communication
21. Cooling
22. Starter control
Any thoughts on this one, price looks very cheep compare to the original package software
See less See more
1 - 20 of 461 Posts
I wonder would you still need the repinned OBD2 to USB patch cord someone was asking about last week?
Where is the link? I've got the cable to test it if someone wants to buy the software.
Wasnt someone looking to buy or borrow one of those cables to try vag com? Is yours repinned for the lamborghini?
Yes. It is pinned for lambo. I looked for the pinout for him but didn't find it.
I thought about making some but not sure I want to take mine apart or have the time.
I'd be in to buy one if you did. For sure. And I understand your time is worth money.
Let's keep this going. I am very interested in purchasing this as well.
Does anyone have the pin out drawing for the cable?
Its hard enough to get knock off vag com cables to work. I'm pretty skeptical that we could get this working without an expert.
I have the OBD2 cable I received when buying FVD software for my 911. I'd donate it if it helps with any of this.
If someone can get this to work, I would buy it in an instant!!!!!
I am thinking I will make a few of the OBD adapters. PM me if interested. If anyone buys this software and sends me a copy, I will give them a free adapter. :)
I'm the guy looking for an adapter or the Pinout info. I bought some stuff to make these cakes but haven't gotten to It just yet.
PM sent AB.
Keep me in the loop.
Gabe
PM sent. I'm in.
I emailed the Guys that is selling this program for 300$.
They answered back:
''I have instruction how to make lambo cable from obd cable''
So the software comes with the instructions on how to make the cable.
I still have my doubts, BUT I would love if someone could get this to work! It would really open up the Lambo DIY world, and significantly lower the cost of ownership for DIY'ers!
I'd probably take the $300 risk and mess with it. Does anyone have insight into the seller?
My concern here is less with the software and more with the cable. Is it USB to OBD or does it need a serial connection. That may require a special pinout of its own.
I find the RS to be more reliable. I have RS232 on my garagelaptop. :confused:
If you take the plunge, could you post the Pinouts for the cable instructions? Just for our reference?
1 - 20 of 461 Posts
