audi uses a totally different one.It would be good if there is an Audi part number for the Thermocouple junction box.
The revised lambo one is actually good. its not expensive either, so why not just get the lambo one?
yup. sounds about right .. .for the entire kit including the box and thermocouples.I probably have to get one as well, I believe $700 or so
Did you see my write up on fixing the controller?Has anyone used the audi a/c controller in a Gallardo? The buttons are different. I am not worried about extra buttons but will it plug in and work properly? The A8 units are on Ebay for as low as $40. Mine is sending full heat even when set to full cold. The heater control valve is fine.
You can try these part #s and double check to make sure they fit but these part #s are from another Lambo site. The front pads from an Audi RS6 are supposed to fit the front of the G and the front pads from a Viper are supposed to fit the back pads of the G. EBC #DP31513C fronts, EBC #DP31470C rears.Looking to replace my front and rear brake pads, 2004 Gallardo, was told that 2003 viper uses the same rear pads, and fronts are RS6. Any recommendations?
Remove them and check😊.anyone know what Audi provides the rear number plate lights?
Do you have some to hand ? they would probably have a part number in the lens.anyone know what Audi provides the rear number plate lights?
