1 - 14 of 14 Posts
Does anyone know if there are o-rings that seal connection from valve covers to(at) sp plug holes and were available. Also are there any shop manual available for Jalpa? Carb. mounting looks a bit challenging to the novice.
Eric
No,
there is the same sealing cover material for the plug holes.
I think I have no more of them, can check this...
gaskets
thank you, also do you know what holds down the boxes the carbs are in? is it the carb mount bolts? thanks.
I suppose you mean the american carb boxes, I can post the picture of the spare parts manual if this helps.
Carb Boxes
Hi Raymond,
Unsure if the carbs have to come off to replace the valve cover gaskets, also you were going to checkto see if you had the gaskets that seal the sp plug holes.
thank you,
Eric
John, he's referring part #23 and #24 of the picture.
I'll check this evening if I have them, got late yesterday when I installed my ignition box on a LP5000s...
Eric,
you're a lucky guy, look what I just found in my parts collection, If I knew that you need them also I would have sent them together with the big gaskets in the same parcel.
BTW did you get it?
To remove the cam cover you can leave the carbs, the front cover should be accessible through the service opening from inside the car (depends on the vin, from around 300 they have this window in the firewall)
Discussion Starter · #9 ·
Carb Boxes
Raymond,
where are the mounting bolts for the carb boxes?, cannot seem to find them, i do have the service window in the cabin.
Could you send me the other gaskets, paypal again.
Thank you,
Eric.
Discussion Starter · #11 ·
carb boxes
it appears the carbs hold down the carb boxes by the carb mounting bolts, if anyone knows if this is the case i would appreciate it.
Thank you,
Eric.
No, just send $30 for the other gaskets, this should cover delivery and paypal fees, they left on Monday and should arrive within one week.
1 - 14 of 14 Posts
