1 - 3 of 3 Posts
Does anyone know where I can get a speedometer cable for a Jalpa other than the dealer? I can't wait weeks to get it. Mine snapped and we are going on a run up to Wisconsin in a two weeks. Is there a similar cross reference one available? Any help is greatly appreciated.
Dave,
The only thing I can suggest is to see if a Countach one will work!
The other choice is get a speedo cable made using the ends of you current one with a new cable welded or fitted. :confused:
Go to any shop that makes speedometer cables. They should be able to make one for you. The ends are the regular ends that attach to regular speedometers, at both ends. Just make sure that the length is correct.
Is the outside of the cable broken or just the inside cable? If it's just the inside, you can buy one of those $1 "help kits" at any autoparts place and replace the inside cable.
1 - 3 of 3 Posts
