Hey everyone, i trust all are well.
So ive been having issues with my jalpa shifting into 4th and 5th gear, and after checking the engine mounts and playing with the linkages, it seems the problem is in the gearbox.
its shifting into all gears, except 4th and 5th. Its not making any wierd noises, its just not engaging those gears.
I need to ask if there is any way of working on the gearbox with out removing the entire engine and subframe ? or do i haft to bite the bullet on this one?
I see that there is a housing near the rear left wheel that seems it will allow access to the ggearbox if I remove the wheel, but i dont know much about gearboxes, so i dont know if this will be enough access.
any suggesting will help. I suspect a fork has come loose and is not engaging when i shift.
Also, if anyone has any teardown pics of a gearbox, that would also really help.
Yash
Yash
