Off the shelf or from behind the counter? Reason I ask is often if it’s behind the counter they want to look it up by make/model/year.I had that same problem and picked up a pack of black ones for GM vehicles that was identically sized at Autozone.
Thanks!Any auto parts store should have them. Should be an off the shelf item.
https://www.autozone.com/screws-pin...31WgjioROr5Jb9SDwfBoCTcEQAvD_BwE&gclsrc=aw.ds
If you can't find them local to you then uncle Amazon has them as well. Here is a pack of 25.
Amazon.com
Nearest Lambo dealer is hours away. And I refuse to pay any extra for the same part just because it says Automobili on the label haha.If the dealership is local to you, just get them from the dealer. They won’t cost much and could save time and hassle trying to source aftermarket.
You could also try your local autobody supply shop.
In addition to paints they usually carry or are able to get many of the clips, screws etc., that are used in most North American and European cars.
Given the VW/Audi association, I would guess that they will be similar or the same.
Do you or anyone know the dimensions of the factory trim clips?Check here... Automotive Plastic Retainer Trim Clips
Looks like they have the dimensions on there as well. I tried the ones at autozone and trimmed them down but it was a pain. That link above has about 5-7 different ones that look nicer than the Autozone ones. Seems reasonably priced too.
Good luck.
They were off the shelf. I just took the one similar to your photo-I want to say it was attached to the back of the leather kick plate that runs along the base of the door-that was the part on my car that was loose. The ones I picked up were black and the top was round not square like yours. I just cut the edges square with a razor and it fit perfectly. I can take a photo of the box with the style number and a photo of the clip itself tonight.Off the shelf or from behind the counter? Reason I ask is often if it’s behind the counter they want to look it up by make/model/year.
Thats a really nice link for a ton of fasteners!Check here... Automotive Plastic Retainer Trim Clips
Good luck.
Keep us posted. I'm sure plenty of others are in the same boat and could use them as well.I went through 6 racks of Dorman clips at a distributor and couldn’t find a match. Unfortunately they were all listed as specific to American or Japanese cars. Some were close but not quite right. I’m heading to VW dealer next…
I happened to have one in my pocket to bring me for comparison!Post the photos then, I may have them, but need to SEE one that isn't broken.
Yep, I have some in stock of the OEM ones and my price is less, BUT by the time you ship them, etc. it's not worth the savings. This will help you out.And I should add they original clips were selling for $16 each. That’s a big FU from Lambo as far as I’m concerned.
