1 - 5 of 5 Posts
huracan lp-610
hi
i tried to search but i think no one has posted anything regarding this, if any one has changed the gear oil on huracan please share some info for oil type and ....
thanks
Huracan Performante 2018
I have changed the gearbox oil on my 2018 Huracan Performante, I used the procedure for the Audi R8 which is pretty similar it has one more drainplug on the Audi gearbox compared to mine.
I could not see a supplier for the oil that was described in the manual Castrol BOT 342A, and as I did not want to get it at the dealer for xxx$ or EUR per liter I contacted Castrol and they recommended Castrol Transmax Dual, which I used.
The oil was a bit darker than the new oil, but I didn't notice any changes in gear shifting up or down, I changed the oil at 30000km and now the car is at 32000km.
huracan lp-610
thanks for sharing, did you also change any special plugs or filters? im not sure to go with castrol that u mentioned or vw group g052529a2
I re-used the plugs, the filter was changed out with a new one.
If you are not sure you can buy the fluid from a Lamborghini or Audi dealership, I was quoted 38.25 EUR per liter, you need about 10 liters. I used 9 liters and 300cc.
The Transmax Dual costed me 10,45 EUR per liter.
huracan lp-610
i ordered most of the plugs and filters from scuderia parts,so i think i will get the oil from audi with the same specifications, thanks again for your time and sharing
1 - 5 of 5 Posts
